This week's upgrades and progress..
Posted: Mon Jun 19, 2017 5:30 pm
Got some nice jobs done this week! Have only had her a few weeks, and she's proving to be superb.
3.0D manual, remapped to around 238, only 83k, 1 owner from new until 3 weeks back, FSH, widescreen nav, dual climate, Webasto (with genuine webasto remote activation), HIDs, etc etc.
So, this week:
- Dashcam installed, with permanent supply using switched feed from within headlining, so no unsightly cabling about the place, and fully automatic operation.
- AUX input cable installed (genuine bmw one, was an absolute doddle to fit, is now hidden in centre console ashtray so can be used as required. Will be replaced by full parrot kit in due course, but I need a day to do that and won't have it for a few weeks)
- SatNav firmware upgraded to v32, and 2017 map disc installed. (Also found the hidden menu and enabled 3D perspective view on the satnav - much better!)
- Front sidelights replaced with LED ones - perfect match for the HIDS and look great. No warnings either. I picked up a spare set just in case!
- 2hrs of T-cut and polish dealt with a few little blemishes and also where it was keyed in the first week of ownership (buggers!!)
- Rear wiper replaced with an E70 arm and blade (the spring had gone on the old one) and new front wipers fitted.
- Small repair to inner light in upper tailgate where the plastic clip was broken - VHB tape is marvellous.
Next steps:
Repair: She's going in on Thursday to have a rear lower control arm replaced, as it's got some play in it. (Not sure yet of the cost!) and have an early MOT put on - its not due yet, I just want the peace of mind and a thorough check over.
Towing: Shes going in the following day to have a second socket put on for towing the caravan, currently only has single electrics.
Hands free: I have a parrot 9200 I pulled out of my Audi - I've now received the proper bmw lead for this, and the 5m extension cable for the loom to run through to the boot - need to double check I have everything before attempting this!
Phone Bracket - I'd like a nice holder for the mobile - so many of them are utter plakky rubbish, any recommendations appreciated.
Mats - I want to replace the horrible chunky rubber mats, with QUALITY carpet ones.
Dead pixels - the Satnav is perfect, but the panel under the speedo has some dead pixels - need to look into whats involved to fix these!
Alloys refurbishing - theyre not scabby at all but are starting to lose the lacquer - would really like to get these back to looking all nice and shiny all over.
Investigate LED upgrades for the main beam. The HIDs for dip are simply superb, but the mains don't really add much at all.
Find some paint to repair a little patch where the matt black paint on the trim round the window has peeled - its only a little bit, but unsightly. Again, all suggestions welcome!
Watch this space! What have you done to yours?
So, this week:
Next steps:
