4x4 warning light on
Johnzzzz
Post by Johnzzzz » Mon Jun 12, 2017 7:51 pm
I have a 2005 x5 30d sport 6 speed, the 4x4 warning light  comes on after I have driven about 7 or 8 miles, if I stop and turn off the engine, it resets and does another 7 or 8 miles and the laght come on again, the gearbox changes smothly and it drives fine with the light on or off, hope some one can help
Cheers john
Re: 4x4 warning light on
Post by Horizon » Mon Jun 12, 2017 7:57 pm
[quote="Johnzzzz"]
Cheers john
Hi and welcome to the forum
Johnzzzz
Post by Johnzzzz » Mon Jun 12, 2017 8:01 pm
I have a bmw 140 but can't get it to work,
Post by Alan Gunn » Tue Jun 13, 2017 7:48 am
What are your tyres like ie size and tread depth on each.
Smeeagain
Post by Smeeagain » Tue Jun 13, 2017 6:57 pm
[quote="Johnzzzz"]
Cheers john
Sit in the car. Is the steering wheel off centre when the wheels are straight? Post back and let me know
Johnzzzz
Post by Johnzzzz » Tue Jun 13, 2017 9:34 pm
It has two new rear tyres, the front ones are 75% worn, the steering wheel is just off center when driving straight ahead
Cheers john
Pete
Post by Pete » Tue Jun 13, 2017 10:27 pm
My old car used to have that warning and it popped up exactly like you say - after approx 8 miles. I had a 4 wheel alignment done and the light stayed out.
kkx5
Post by kkx5 » Tue Jun 13, 2017 10:45 pm
Read the error codes or get someone to do it.
Smeeagain
Post by Smeeagain » Thu Jun 15, 2017 12:49 pm
[quote="Johnzzzz"]
Cheers john
As someone else said it is likely that it is the tracking. So your wheels tyres are straight and the steering wheel isn't so it is throwing the readings out on the steering angle sensor.
That's why I was asking where the steering wheel sits.
First port of call is to get the tracking down - it needs done anyway, and will wear out tyres if not done. needs to be someone who has the kit to do four wheel drive alignment as I recall.
They should also then have the kit to clear out the error code.
You'll soon know if that has fixed it or not as the light will come on or it won't.
It may be that the steering angle sensor needs replaced, it could be that its a wheel sensor, it could be an issue with the diff and so on. But as your tracking needs done anyway start there and report back
Smee
Smeeagain
Post by Smeeagain » Fri Jun 16, 2017 10:42 pm
As it happens I now have the same issue. i start up, no warning lights. i drive anywhere between 200 yards and a mile and then the light comes on. sometimes it will flicker on and off for a few hundred yards then stay one. Steering wheel is off centre so tracking is being done next week. we shall see.......
Smee
Smeeagain
Post by Smeeagain » Wed Jun 21, 2017 5:31 pm
Tracking done today. All aligned and warning light has stayed off
Smee
Pete
Post by Pete » Wed Jun 21, 2017 7:33 pm
[quote="Smeeagain"]
Smee
Glad to hear it. It's the obvious one that most don't do first.
Smeeagain
Post by Smeeagain » Fri Jun 23, 2017 12:04 am
[quote="Pete"]
[quote="Smeeagain"]
Smee
And can save a few quid on not having to replace tyres too by getting it done. My local place only charges to adjust not to check so I get it checked twice a year when the summer/winter wheels/tyres get swapped over and back again
Smee
