PDC error
- Upex
Re: PDC error
I think they are individual sensors, but could be wrong. I'd expect more errors if the controller was fried etc
- ianst0028
Re: PDC error
rear centre left sensor is faulty and the bleeper under the dash for the front sensors is too*
*at least thats the way i read it
X5 e53 3.0 2002 with LPG
Re: PDC error
[quote="ianst0028"]
+1
+1
centurion
Re: PDC error
Cheers guys... much appreciated.
Can it be replaced w/o taking the bumper off or...?
- ianst0028
Re: PDC error
[quote="centurion"]
The centre ones at the rear can be accessed via the blanking plate that's for the towbar. ( if you have a towbar, maybe not so easy )
Put your hand in and feel for the rear of the sensor, at the bottom of the sensor holder there is a tab pull the tab and this allows the sensor and holder to be easily pushed out, then you can unplug the cable.
The new sensor will need to be fitted into the holder . Put it all back in and job done 5 Minute job the second time you do it, as said fiddly first time until you see how the tab/ securing ring works.
Lyons
Re: PDC error
Are the rest of your sensors still working? My car gives the long beep from the front speaker when I put it in reverse now, but the rear sensors still appear to function. I thought if 1 was faulty they all stopped working.
What software did you use to scan?
Re: PDC error
I had a faulty one on the back but the front ones still worked.
Did get the long bleep when first put in reverse and the flashing green.
centurion
Re: PDC error
[quote="Lyons"]
I used DIS - readily available from fleebay and comes supplied with a cable and software.
Hope that helps
Hope that helps
centurion
Re: PDC error
Replaced and works fine now.
Quick question - where do i find a buzzer for front sensors?
- ianst0028
Re: PDC error
it's under the steering wheel ..... if you remove that panel you'll find it
