I'm at a loose end here. My 2004 3.0D is still making an intermittant rumble / groan / vibration from the rear.
- I occassionally tow a caravan and this makes it slightly worse, but it is there at all different times.
More often than not around 40 mph
If i floor it, the rumble is loud
If I corner with a bit of speed, the vibration is bad, but it can vibrate a lot on a straight road too.
It has recently had:
- All new tyres
Hunter wheel alignment
Full service
Rear brake calipers stripped and cleaned (they thought it could be a sticky caliper)
Thanks in anticipation.
