Although I've got xenon adaptive lights on my e70 35d the angel eyes are normal H8 bulbs.
I'm thinking of swapping to these
http://www.ebay.co.uk/itm/H8-Angel-Eye- ... 2548.l4275
Has anyone else used them or can recommend anything else?
cheers
LED angel eye upgrade
- PokenH00D
Re: LED angel eye upgrade
Before you spend £££'s on a disappointing result, check some threads on here.
I, like others, got quite expensive LED's and have gone to a good quality Halogen as the LED bulbs doesn't seem to work too well with the lights meant for a normal H8
I'm in Mansfield if you want to try some before shelling out your cash.
I use nothing more complex than these...
http://www.ebay.co.uk/itm/MTEC-H8-12v-3 ... SwpDdU7yy0
They are white in colour, as bright as the original H8 and a lot cheaper than LED with similar looks. There are no current LED replacements that will give you the 'LCI look' because of the challenge of getting the light source to couple into the light pipe inside the headlamp.
Photo taken in full sunlight and have now been fitted for more than 5 years with no problems or failures.
Never anthropomorphise computers. They hate that.- moggyboy
Thanks for your replies.
I will check out the ones you have recommended X5Sport, for £15 what the hell!
cheers
cheers
