Map on Satnav Screen
Insight G40
Post by Insight G40 » Wed Apr 19, 2017 9:21 pm
Evening,
How do I get my satnav to display maps like the pic below? Is it just a change of setting, or as I more likely suspect a change of the nav software?
I have the same nav unit.
E53 Sept 2006 3.0D Sport
Re: Map on Satnav Screen
Post by X5Sport » Wed Apr 19, 2017 10:23 pm
Turn perspective mode off?  I'm assuming that's what you are asking?  You can also change the range to suit, but I am assuming you knew that.
Insight G40
Post by Insight G40 » Wed Apr 19, 2017 10:32 pm
I don't have a map on screen at all, just an arrow pointing in the direction I should go.
Post by Horizon » Wed Apr 19, 2017 11:38 pm
[quote="Insight G40"]
Can't speek for the X5 , as mine had an aftermarket headunit, but my X3 has the MK4 satnav system, but a pop up screen so different controls.
Mine comes up with the arrow view, but if I press the right hand button, another menu appears and I go to map view, and the map appears. The one on screen is zoomed out to 50 miles, you can zoom into 150 yards to make it workable.
Some one will explain how to do it on your head unit I'm sure
grumpywurzel
Post by grumpywurzel » Thu Apr 20, 2017 11:08 am
Looks like its zoomed all the way out, trying to remember but I think it's in the options screen, normally its zoomed into 200 metres possibly?
2005 X5 3.0d Sport
Lyons
Post by Lyons » Thu Apr 20, 2017 11:16 am
The X5 Nav is the most complicated unit I've ever used!
RickUK
Contact:
Post by RickUK » Thu Apr 20, 2017 11:34 am
Cannot help you with you question as my X5 did not come with a SatNav unit,but in recent days asked for help on what is the best option and almost all have suggested a aftermarket one,so this weekend Halfords are fitting a Garmin for me,must admit i am glad i did not go down the factory fitted option as they do seem complicated too setup and use.
I could of course be totally wrong as i have only just had my X5 over a month,but the simplicity from my old TomTom of just tapping in my destination post code all 10 seconds and then my home destination for the return trip  ;)
2006 '56 BMW X5 D M SPORT LE-MANS EDITION
http://www.hideones.info
Post by X5Sport » Thu Apr 20, 2017 12:51 pm
The Mk4 fitted to the E53 was not the best example of a Nav system!  It could not even work with UK postcodes for many years.
Fitting an OEM one now would cost more than the car is worth!
Insight G40
Post by Insight G40 » Thu Apr 20, 2017 7:55 pm
It can be made to work with UK postcodes? How?
Post by X5Sport » Thu Apr 20, 2017 9:52 pm
From memory I think you need the latest firmware version and OEM map disks from about 2008?  The car was out of production by then, but I am almost certain that BMW fixed something as long as you had genuine V32 firmware.  Use of non OEM messed things up - but may be fixed now.
DARTH510
Post by DARTH510 » Fri Apr 21, 2017 6:55 pm
My x5 has postcode now, uploaded v32 firm ware
DARTH510
Post by DARTH510 » Fri Apr 21, 2017 6:57 pm
To get to map from directions screen, push right hand knob, then,  scroll down to map,  push again.  To zoom in or out,  rotate the right knob.
Upex
Post by Upex » Fri Apr 21, 2017 8:17 pm
[quote="DARTH510"]
how does one get the v32 firmware, visit to dealer? Would love postcode search!
Post by X5Sport » Fri Apr 21, 2017 9:31 pm
The only legit way is to go and ask your Dealer nicely for the CD.  Some will let you do it in their car park, others.....
You can get it on line however it has usually been modified to add extra POI like speed cameras but that affects the language pack and if you turn them off the language changes to French!
Postcodes do work anyway, just not the 7-digit version.  You can enter them in the Town/City field.
It is worth checking which version you have anyway as it might have been done.  Check under Menu > Settings and let us know what numbers are at the top right.  If it says 4/2-00 then you have V32 already.  That indicates firmware OS build 10.0 is loaded.  Earlier versions confusingly have higher last numbers like 93 (OS Version 9.3).  The 4 is for the DVD Nav (Mk4) and the /2 is for the colour screen.
X5-D-Sport
Post by X5-D-Sport » Sat Apr 22, 2017 10:58 am
I believe I have V32 firmware on a spare disk.
I bought a bloody expensive OEM disk from e-bay last year... and for some (marvelous) reason they sent me 2 disks sets..
Go halves on the cost for the spare disks + maps..
Or if you are close to the West Midlands, I will gladly upload it to your vehicle for you.
