Our X5 was previously owned by a farmer so you can imagine the interior how muddy it is. I was hoping to give it a full wash or steam clean and was wondering if I can remove the front seats for better access. Would I need to recode the electric seats if I took them out or would it be ok to replug them after clean?
thanks
interior full valet
H-M3
interior full valet
current cars
2009 X5 3.5D
Audi A8L 4.2tdi 2006
Seat Ibiza 1.4tdi (£0 Tax)
Renault Megane 1.5dci 2004 non runner
2009 X5 3.5D
- snrbrtsn
Re: interior full valet
The seats will be ok to remove and no coding required to refit
However
The battery will have to be disconnected and allow sufficient time for ecu to shutdown (circa 16minutes) otherwise you will get SRS Airbag fault when the wiring is disconnected under the seats.
However
- Steamyrotter
[quote="snrbrtsn"]
ECU will immediately shutdown on Battery disconnect...
There are no internal battery backups for most functions.
To make sure the car systems have discharged then after removing the battery connections from BOTH terminals, touch the -VE & +VE leads together. Gets rid of any stray build up anywhere.
