Speed Sensitive Volume
Posted: Thu Feb 24, 2011 7:21 pm
by pvw10
On my last Beemer (e46 m3 rag top) i just pressed and held the "m" button to access the menu to alter the speed sensitivity volume.Does anybody know if/where the e53 with sat/tv is or even if it has this function ?
Paul
Re: Speed Sensitive Volume
Posted: Fri Feb 25, 2011 3:01 am
by Turks
I thought this was only an option on the convertibles? When the roof is down, you have no protection from all the noise around when driving so the volume increases with speed?
Turks.
Posted: Fri Feb 25, 2011 10:53 am
by petert
I recall there being an option to adjust this on the OBC.
Peter T
Posted: Fri Feb 25, 2011 1:46 pm
by Turks
It would be good if there was this option, always feel a bit stoopid when I have the windows down and I stop at the lights with the music blaring!
Turks.
Posted: Fri Feb 25, 2011 1:51 pm
by StumpyPete
My E53s both had this, but I can't remember how you set it....4 years ago almost now since I switched to an E70.
Posted: Sun Feb 27, 2011 11:39 am
by kena
Just did a google search and came across this.
Check out the attached pdf file...
HTH
http://www.bavariansoundwerks.com/knowl ... n+your+BMW
Posted: Sun Feb 27, 2011 11:49 am
by pvw10
Brill great find, seems there are three ways for e53 with nav so will try them all.
At the bottom is says no good with DSP cars so still fingers crossed.
Thanks for digging this out, top banana.
Paul
Posted: Sun Feb 27, 2011 12:16 pm
by pvw10
Top Man Kena it works !
On mine with tv/nav this one worked so others may benefit (thanks to Kena)
Turn radio on
Press and hold "select" until service mode appears
use to cycle around choices until you find the volume bit "galv" or similar (mine was on 1)
Use preset keys 1 or 3 from memory to alter, mine now on 6 and it works a treat.
