Random Self Level Susp Inactive message
Smeeagain
Post by Smeeagain » Wed Apr 05, 2017 8:19 am
Anyone had this come and go (E53 2004 3.0 D Sport Auto).
I was driving along today and "check tail light" and "check brake light" message, came on. Went over a bump and it went off. happened a couple of times. Previously when the has happened I've taken the bulb out cleaned the connector and it's sorted.
Anyway I got to my destination and the warning came on again. I switched off, went and did what I had to do and came out and the SELF LELEVE SUSP INACT error came on but no brake light build message. Decided to drive to my next destination about 20 mins away. Got there switched off, switched on and all fine no errors. Car drives fine and suspension looks/feels ok
Thoughts? Battery problem maybe? Brake light issue has shorted /tripped something (but then reset ????)
Anyone had this come and go before?
CondorX5
Re: Random Self Level Susp Inactive message
Post by CondorX5 » Wed Apr 05, 2017 8:44 am
I had it happen a lot with my E53 a few years ago. When it tends to randomly come and go, it seems more related to battery issues or possibly even alternator charge issues.  When it stays on permanently when you turn ignitin on, it seems to be the air suspension -in my case, battery was changed and it went away. Then it returned and ultimately traced to alternator which was replaced.  Then it returned after a while on a permanent basis - air suspension replaced bit by bit, mostly under warranty thank goodness.
I would start with the battery as its easiest and cheapest.  Also worth knowing that with E53s its best to turn igniti N to position 2 and let the lights settle- like a computer booting up - before turning engine on - sometimes turning engine on too fast can lead to these random errors.
Smeeagain
Post by Smeeagain » Wed Apr 05, 2017 8:54 am
Thanks, yes Im a great believer it always letting the lights settle on the ignition before starting. Will stick the car on the CTEk conditioner overnight first and take ti from there
Smee
grumpywurzel
Post by grumpywurzel » Wed Apr 05, 2017 12:03 pm
If I start mine too quickly I have had on the odd occasion the Low Oil pressure/level alarm.
To quote a Monty Python sketch " You lucky, lucky B***ard" I dream of just having a check brake light warning  :))
2005 X5 3.0d Sport
Smeeagain
Post by Smeeagain » Wed Apr 05, 2017 1:40 pm
X5-D-Sport
Post by X5-D-Sport » Wed Apr 05, 2017 4:20 pm
I get a brake light warning occasionally lol    :P
may also be worth checking your battery voltage, pre-start & when running..
If.....when the vehicle is not running, the voltage sinks to 11.5 volts or lower, it can cause all sorts of error messages.
Rule of thumb...
12.3v + when idle
13.5v + when running
if you are not achieving the above, then error messages may well start annoying you.
Smeeagain
Post by Smeeagain » Wed Apr 05, 2017 5:04 pm
And I can check that at the charging points under the bonnet, yes?
Post by X5Sport » Wed Apr 05, 2017 5:47 pm
Yes.
Livelee
Post by Livelee » Wed Apr 05, 2017 6:48 pm
I used to randomly suffer from this.  Turned out my car had a xenon light kit fitted (i never knew).  A bulb went and I discovered them so pulled it all out and fitted normal bulbs.  Suspension warnings gone and lights are fine. :)
Post by henrym3 » Wed Apr 05, 2017 8:58 pm
Smee, get into that secret menu and No7 is battery voltage, you can watch it as you drive along
VW R32 Gone
Smeeagain
Post by Smeeagain » Wed Apr 05, 2017 11:48 pm
ok, will do
Smeeagain
Post by Smeeagain » Wed Apr 05, 2017 11:50 pm
This link here says do not start the car when accessing the menu? You are saying it is ok? Or have I misread it?
http://www.ronstultz.com/knowledge/Docu ... ctions.htm
Smee
themoog
Post by themoog » Thu Apr 06, 2017 8:48 am
One of our X5's used to get the suspension message. I took the fuse out for the pump and put it back in and have never had the message since. The light units need to be removed and all the contacts cleaned to get rid of brake bulb error message.
grumpywurzel
Post by grumpywurzel » Thu Apr 06, 2017 11:43 am
Just remembered I did have that suspension error once.... not surprised as I nearly had the old girl on two wheels, so no wonder the system was having a hissy fit  >:D
2005 X5 3.0d Sport
Post by henrym3 » Thu Apr 06, 2017 10:02 pm
Smee As I didn't know of or read that link, good link btw, I blundered ahead and watched the coolant temperature as I drove along, have had no adverse effects and if you look at test 7 one of the facilities is to observe your current speed and RPM. Can't do that with the engine off. In fact, today, while sitting in heavy traffic (engine running) I just held the r/h button in and it went to test 1, scrolled to 7 and watched the coolant fluctuations. It would appear that once you have unlocked it, it stays unlocked, presumably until you disconnect the battery.
VW R32 Gone
