E70 doing a regen at approx 75 miles
martin33100
Post by martin33100 » Sun Mar 26, 2017 10:05 pm
Hi guys, did a 200 mile trip today, 100 miles each way.
Had my C110 scanner connected just to check coolant temps and I also noticed the car did a regen on the way up and on the way back home.
Isn't that a short distance to do two regens?.
If I do the static back pressure test on ISTA I get aprox 12,56,115mbar so my DPF back pressure is still below BMW's max limit.
Domowilko
Re: E70 doing a regen at approx 75 miles
Post by Domowilko » Wed Aug 02, 2017 7:10 am
Could i ask what is the max limit. Thanks
Sent from my SM-G935F using Tapatalk
Nine468
Post by Nine468 » Wed Aug 02, 2017 10:53 am
Martin, maybee it needed it..
At least its doing them....
Dave W.
BMW G05 X5 40D
Post by X5Sport » Wed Aug 02, 2017 5:58 pm
If the first didn't complete then it will try again.  I have had my X6 regen each way in a 90-mile run and put it down to shorter trips in between not quite clearing the soot.
