Any useful Carly coding ?
snrbrtsn
Post by snrbrtsn » Fri Mar 24, 2017 10:48 pm
Just got the Carly adaptor......
To be honest it's pretty useless out the pack and ones tied into upgrading to the pro version, which I did...
Primary function was to monitor coolant temps as my driving habits will kill the emmission system, so now I can monitor the trends and take out for dpf blasts as and when required, (though the recorded soot & ash values are beyond me, what should they be ?)
it's also going to prove useful for battery trends as car sits for three weeks at a time.
Had a brief look on the coding (as much as child would allow) coded the dash lights on all the time, which is useful as the E70 interior is dark when used to the black panel panel display and some other random bits.
Had a look through fault codes, three codes relating to pano roof, which I'm hoping relates to the time the towbar was fitted, battery disconnected and roof wouldn't close from tilt as required reintialised.... after this roof has been faultless and used often.
Though was wondering if anyone has delved deeper and found some good bits...
I already had the boot opening from the fob, though hope to get the close from fob, function also ???
CondorX5
Re: Any useful Carly coding ?
Post by CondorX5 » Sat Mar 25, 2017 8:01 am
I managed to code the boot opening and closing from the fob quite easily with the Carly - is yours only working to open it?    Also did the mirrors fold from fob - some of these were two part codings, you had to go into different screens to set them correctly.
PokenH00D
Post by PokenH00D » Sat Mar 25, 2017 8:44 am
I did
Boot close from fob
Boot close from dash button
Mirrors fold on lock/unfold on open
Digital speed in dash
Tail lights off with DRL
DRL intensity very high
Camera warning off
I coded for indicators in HUD but it doesn't work.
I activated the DPF option so I could monitor the the soot volume.
Scanned for errors a few times, different ones occur, but none have reappeared after clearing.
2010 E71 X6 40d. Pearl Silver Metallic.
Carly Pro
snrbrtsn
Post by snrbrtsn » Sat Mar 25, 2017 10:56 am
[quote="CondorX5"]
I've yet to try & code the remote boot closing, it currently works off the fob to open
The mirrors already fold from fob, though believe these can be coded to unfold on unlock as opposed to once driving
snrbrtsn
Post by snrbrtsn » Sat Mar 25, 2017 11:00 am
[quote="PokenH00D"]
I did
Boot close from fob
Camera warning off
I'll be looking at the digital speedo
I'll have to look up what the dpf soon levels mean to make use of the value
For some reason I thought I had enhanced Bluetooth, though cindecoder suggests otherwise, I'm going to try and see if the coms box offers any Bluetooth streaming function, I thought & most possibly incorrect, that Bluetooth streaming was part of the individual audio package, there's a menu for it, just no function (as yet!)
PokenH00D
Post by PokenH00D » Sat Mar 25, 2017 11:10 am
[quote="snrbrtsn"]
[quote="PokenH00D"]
I did
Boot close from fob
Camera warning off
As I understand it the soot level will go to around 32g before the car requests a regen.
Mine got to 43 then I did a run down to Surrey on Wednesday, when I got there it must have done a regen as it was at 29. I checked it when I got back from Surrey, having had a traffic free motorway run back and it was 9  :)
Carly Pro
snrbrtsn
Post by snrbrtsn » Sat Mar 25, 2017 5:16 pm
Thanks I'll be having a look tonight and may be forced into stretching those legs!
snrbrtsn
Post by snrbrtsn » Sat Mar 25, 2017 7:38 pm
[quote="PokenH00D"]
I did
Boot close from fob
Camera warning off
How do you get the boot to close from fob?
I coded it but no joy... it opens no problem just not closing (yet)
PokenH00D
Post by PokenH00D » Sat Mar 25, 2017 7:51 pm
[quote="snrbrtsn"]
[quote="PokenH00D"]
I did
Boot close from fob
Camera warning off
I just coded it, but made sure the panic alarm function of the fob is coded off.
Also, it only goes down while the button is pressed.
Carly Pro
snrbrtsn
Post by snrbrtsn » Sun Mar 26, 2017 2:58 pm
Got it working now thanks
Double tap the fob to get the function
Works off the dash switch as well allbeit press once to open press once to close
Played a bit more and got all sorts of things including the digital speedometer, mirror fold on lock, dash lights on all the time, chirp when locked, brighter cornering lights, flash with fog lights and changed the daytime driving lights,
Quircky but not essential
I also tried having the doors lock with ignition key in, though that lasted all of the 3 seconds so reverted back
brandon888
Post by brandon888 » Wed Mar 29, 2017 6:11 pm
Anyone got the link where I can purchase carly .  :)
PokenH00D
Post by PokenH00D » Wed Mar 29, 2017 6:14 pm
The dongle is on Amazon.
Even if you try to order from the Carly site, it points you to Amazon.
The app is in the Apple App Store, or Google Play.
If you're near Nottingham I can show you it working before you purchase.
Carly Pro
