Level control system failure
Posted: Thu Mar 23, 2017 7:35 pm
by bubbabear
Message just appeared on my idrive. Its a yellow warning light - anyone got any ideas as to what the fault may be?
Re: Level control system failure
Posted: Thu Mar 23, 2017 8:16 pm
At a guess it could be the self levelling suspension system.  Could be faulty sensor on either axle, failed airbag (you'll see odd ride heights), failed compressor, leak in the airlines, blown fuse or a spurious error (caused by flat batteries on the E53 so may occur in the same way on the E70).
Posted: Thu Mar 23, 2017 10:26 pm
by bubbabear
Thanks i had a leaking air spring on my E39 but it was 12 years old and just moved 3.5 tonnes of soil from my garden. Thank goodness the x5 is under bmw warranty.
Posted: Fri Mar 31, 2017 11:07 pm
by bubbabear
So car was at main dealer this week and they diagnosed water ingress into a rear ride height sensor so will be replaced as a pair. They also found some cracks in some bushes so again will be replace FOC under warranty.
Its really refreshing to have a service agent who
1) returns phone calls
2) genuinely wants to help you as a customer
3) goes out of their way to accomodate your needs
So congrats to BMW Battersea for a really pleasant experience....(unlike Coopers Thames Ditton!)
Posted: Fri Mar 31, 2017 11:10 pm
by bubbabear
Using my Carly App i ran a diagnostic check and gave the dealer all the fault codes...dealer will replace battery for alarm FOC.
