Post
by graemeX5 » Tue Mar 21, 2017 7:24 am
I am not sure which part you are referring to on the left, but if you meant the rectangular metal block with two plastics caps that is attached to the left (offside) front suspension mount then this is to do with the air con cooling system.
Please see link below and according to diagram there appears to be only two metal pipes that connect to that block it for European models, if you mean there are another two threads on the metal block i don't know but an educated guess would be they are to do with the bleeding of the system.
I am sure X5Sport or one of the others will able to confirm this
http://www.realoem.com/bmw/enUS/showpar ... Id=64_1577
graemeX5 on Tue Mar 21, 2017 7:26 am, edited 1 time in total.
