Evening
I searched and couldn't find an existing thread
I'm looking to buy a 2012/2013 X2 20D but none of them have SatNav
How easy / costly is it to purchase whatever is the standard BMW satnav unit? If that's possible
Aftermarket Sat-Nav
- mogsyman
Re: Aftermarket Sat-Nav
[quote="Simon321456"]
Evening
PVR is your man, he's added BMW sat nab to a Z4
Not cheap and not easy from memory however he'll confirm.
Evening
2019 F90 M5
2019 Porsche Macan
Previous
2016 X3 20D M Sport
2016 X5 M50d
F10 M5
120D M Sport
335i DCT Vert
997 C2S
30D M Sport X5
2.0D M Sport X3
535D M Sport
4.8iS X5
3.0D M Sport X5
320D M Sport Cab
996 C2 Cab
Boxster S
Golf GTi (150 D)
2019 Porsche Macan
Previous
2016 X3 20D M Sport
2016 X5 M50d
F10 M5
120D M Sport
335i DCT Vert
997 C2S
30D M Sport X5
2.0D M Sport X3
535D M Sport
4.8iS X5
3.0D M Sport X5
320D M Sport Cab
996 C2 Cab
Boxster S
Golf GTi (150 D)
No official retrofit kit from BMW meaning you will have to identify and buy the parts you need. It won't be cheap. A Garmin will probably do a better job for the price of the map disc for a year.
BMW do a removable Nav kit.
Realoem has all the current available retrofit kits. Copy of the current BMW parts database.
G_M_S
You should be able to use the following from BMW
https://www.bmw.co.uk/en_GB/topics/disc ... 10617.html
It's not quite the same as the original Business Navigation, but it does use your original screen and updates the menu so you select SatNav in the same way and gives you an updates sat nav controller dial with the Nav Button
brandon888
