Remapping and DPF
martin33100
Remapping and DPF
Post by martin33100 » Tue Mar 14, 2017 9:30 pm
I have run a few remapped diesels in the past and still have a tuned VW T5 but non have had DPF's or the DPF's have been removed.
As the MOT is due to be having a DPF particle test added sometime in the future I don't really want to remove the DPF from our E70 but I may get it remapped.
Has anyone run a remapped 3L diesel for a long time with a DPF with no issues?
martin33100
Re: Remapping and DPF
Post by martin33100 » Mon Mar 20, 2017 1:42 pm
Do most of you guys run standard un tuned  X5's?
Glen
Post by Glen » Mon Mar 20, 2017 3:29 pm
Hi Martin
I was thinking about a racechip because it can be easily removed and I would not want to screw up my warranty.
And then again I have the 40d and it goes like a train so in two minds
https://www.racechip.co.uk/shop/bmw/x5-e70-2007-to-2014/40d-2993ccm-306hp-225kw-600nm.html
2012 X5 40d msport Mine now gone :(
2010 320d convertible WIFE'S
martin33100
Post by martin33100 » Mon Mar 20, 2017 4:21 pm
[quote="Glen"]
Hi Martin
[/quote]I have provisionally reserved a Superchips Bluefin through my local Euro Car Parts at a much more reasonably price, if it works out well I will PM you the details if you want.
Glen
Post by Glen » Mon Mar 20, 2017 4:27 pm
Definitely Martin look forward to hearing the verdict
Post by X5Sport » Mon Mar 20, 2017 6:01 pm
[quote="martin33100"]
I think the answer to that question is yes.  There are a few who have had remaps done by Jason (jason@bwchiptune) on the Forum, but the majority leave them as is.
One of the issues, especially with the E70 and newer is that if they go to a main dealer then the servers in Munich detect the remap, assume there is an error and overwrite it automatically.
BMW have also started locking the ECU meaning it must come off the car to be done - unless that little wrinkle has now been got around?
martin33100
Post by martin33100 » Mon Mar 20, 2017 9:55 pm
[/quote]I thought that was the case with most people leaving things standard on here, can't say I use the dealer anymore or ever have done, I work on engines most days at work and now I have the dealer ISTA D and ISTA P sofware I hope to fix most things myself when they come up on the X5.
I am still a petrol head at heart, even my VW T5 sportline has 287hp/625nm under the bonnet but that's has more than just a simple remap done to it, hope to be pushing 300hp+ if I ever get time to fit my bigger injectors.
jagr
Post by jagr » Tue Mar 21, 2017 8:56 am
I have the DTUK CRD2+ and Pedalbox on my X3 3.0sd and have no complaints.
https://www.diesel-performance.co.uk/sy ... php?id=192
2011 BMW X3 30d M Sport
jason@bwchiptune
Contact:
Post by jason@bwchiptune » Sat Apr 15, 2017 3:23 pm
I have tuned many bmws in my years as a bmw independent and bmw tuner  and I have proven that there is no need to remove the Dpf
Remember the companies that recommend removing the Dpf by telling you you will get more power don't tell you the truth that your car will be illegal to use on the roads, you will loose lower end torque and they every one they do they will sell your Dpf internals for cash to put in there pockets
These companies will also recommend removing the Dpf when there is nothing wrong with the Dpf system only to make more money from you
Sent from my iPhone using Tapatalk Pro
TUNING DEALERS ACROSS THE UK
DYNO DYNAMICS ROLLING ROAD
http://www.bwchiptune.co.uk
02085611818
