downgrade MKIV satnav
Posted: Mon Mar 13, 2017 6:52 pm
by neilbm
does anyone know if it's safe to downgrade the satnav?
I've a "High" MKIV system in the trunk and have got version 4-1/01 displayed on the computer, which I believe is v32.1 customized version
I have got hold of a copy of V32 software but am wondering if it's safe to downgrade to V32 from what I have? anyone?
Re: downgrade MKIV satnav
Posted: Tue Mar 14, 2017 9:13 pm
by neilbm
just went for it in the end, crossed fingers and all that ... all fine
Posted: Tue Mar 14, 2017 9:27 pm
Glad it went OK. The only real worry is if the firmware disc is a poor quality copy (unless you have sourced an OEM one) as these drives can be fussy about the discs they are fed. Rarely, but it does happen, the drive 'bricks' and getting it to recover can be painful.
Posted: Wed Mar 15, 2017 8:13 pm
by neilbm
ta
only problem i need to sort now is the car has turned french on me unless i have the speed camera alerts on. i guess that's because somewhere the car is programmed to use french?? how do i change it? cheers
Posted: Wed Mar 15, 2017 8:54 pm
Copy discs have this issue. Genuine discs don't have speed cameras on them, or didn't have. Have you checked the software version number to make sure it is correct?
Posted: Wed Mar 15, 2017 9:23 pm
by neilbm
pretty sure this is correct?
Posted: Wed Mar 15, 2017 9:50 pm
by Horizon
Get a genuine disc off eBay. The discussion on copy discs is not allowed on this site.
Posted: Thu Mar 16, 2017 7:29 am
by CondorX5
That is non OEM software - as said the BMW system disc does not have camera alerts. And the French language change is a well known issue.
Get a proper disc - non OEM software cannot be discussed on here, its against forum rules.
Posted: Fri Mar 17, 2017 7:12 am
by neilbm
oops ok i wasn't aware it was non OEM. so what version would be OEM? or should i say what numbers should be visible in the config menu if genuine software loaded?
i wasn't attempting to chat about copy discs, just to understand who i fix this stuff for me, honest guv
Posted: Fri Mar 17, 2017 4:36 pm
The numbers match the last official version but the disc you have may have added new voice/function files from a 'modified' batch file. Whether you can get rid of that bit once installed is unknown, but try a genuine map data disc and see if it disappears again.
If you are getting French with Speed Cameras off then it's a modded disc. Something to do with the way the voice files have been coded.
Your BMW Dealer may know how to factory reset the firmware and then bring it up to Version 32....the last official release.
