Been trying to fix a rear entertainment system in the back of the x5 (2005) and come across a few bits that I wonder what they are for, so I'd appreciate any thoughts and answer:
These 3 cables come out of the centre console, below rear cup holders and the aux in/out plugs and TV button.
The above is what the 3 plugs look like.
Any ideas what these are for?
Also, there is a rubber strap under the spare wheel, seems to be coming from under the battery cover bolt down thing that is between spare wheel and battery:
There is also a empty plug that looks like an obd2 type connection, it's in spare wheel well at the tail gate right side:
Now I know this is a ski hatch before the banter kicks in, but, I think this is sealed up. Can't get it to open up at all, so wonder if all cars have the hole but only those with optional ski hatch got a blocking plate that can be dropped down, others without option were blocked off?
Last one, for now ::) is that looking at fuses in rear compartment, fuse 77 (I think) is marked up as rear seat adjustment and carries the correct rated fuse. I've checked it's just not a spare stuffed in blank slot, but the slot has the metal contacts in. Given I can't find any adjustment buttons to indicate that the rear seats do move, either in boot or pillars etc, I don't think I have adjustable seats, so what the heck else would be on that fuse? Any ideas?
Cheers for any help folks, Upex
Edit: sorry for the size of pics, not sure how to reduce
