Last year the retaining pins for the parking brake shoes pulled through the back plate on the drive side and was rattling like mad. The other day I noticed the nearside was clattering so today I got my new impact gun out (why didn't I get one years ago) whipped the wheels off and sorted that.
Then I actually set up brake how its supposed to be done and low and behold I now have a working park brake. What a revelation. It actually holds the car even in drive!
Next on my list is the mega camber of the rear wheels to fix. Then the loose steering arms to replace. The list seems endless at the moment but I'm determined to sort it all out.
If your park brake is rubbish I suggest getting it set up correctly. It's ace!
	parking brake
- ianst0028
Re: parking brake
just out of interest how did you fix the pulled pin problem ...... i used brake spring washers on the back of the plate but i'm not happy with it and am seriously thinking about replacing the whole backing plate
			X5 e53 3.0 2002 with LPG
				themoog
Re: parking brake
I didn't have the pin washers so I crushed some stainless washers I had in the garage into an oval shape. I cut 1 1/2 coils off the springs to compensate for the extra thickness then put it back together. It will be ok, I can't see them popping off. I did consider getting new backplates last year but they have to be cut in a certain way to fit if you don't want to remove the hub, so no..
