Factory fit tow bar replacement
Well the fault that gives you a bit of a shock when towing the caravan tow bar not locked second time it's cropped up and we are now fitting tow bar no two guess that's three with the original factory fit here hoping this doesn't happen again
X5 F15 30d msport
5 series g31 20d
5 series g31 20d
Re: Factory fit tow bar replacement
Tow bar replaced just the caravan to tow when I pick it up from servicing shortly hopefully no more shocks
X5 F15 30d msport
5 series g31 20d
5 series g31 20d
Hi allforus
was that the westfalia retractable factory fit towbar?
if the westfalia is the factory fit then that's the one i Spec
It from new
It from new
X5 F15 30d msport
5 series g31 20d
5 series g31 20d
