[quote="ammo23"]
[quote="cozycoupe"]
Well, I must admit I've spent most of my time in Eco-Pro in some weird (pointless I know) quest to see what MPG I can get. I also find the response a bit smoother when pulling off.
Since I spend most of the time in Eco-Pro and since it has been pretty cold recently I was thinking to myself that my heated seats weren't as good as I remember and thought I might have some sort of fault. Then I found out that there was a config setting that sets the heating system to a more economic mode. I just didn't realise it affected the heated seats! Lesson learned.
Funnily enough I've been trying to better my mpg this week! I've found the drive to be smoother just setting the cruise and using the thumb up/down to adjust speed (and that's suburban driving!)
Ah, so eco-pro adjusts the seat heat, I'd have not thought of that!! Can that setting be adjusted whilst still using eco mode or did you have to revert back to comfort for heat?!
Yeah, I didn't think of it either and was close to complaining about it!
I found I couldn't just disable more economic seat heating as a stand alone parameter but disabling the eco-pro climate setting does the trick.
I also like the 'coasting' in Eco-pro too. I'm not sure if you get that in other modes.
