have replaced halogen to hid spot bulbs.
lezmtaylor
Post by lezmtaylor » Wed Jan 25, 2017 3:44 pm
I have replaced the halogen spot bulbs to 35w hid/ballast bulbs.on the wife's E46 2003
What resistor do I need to solder into circuit to defeat the bulb error light.
A'' how to'' would be handy , or another forum answer (E46), and will I have similar probs when I do this on my E53 ?
Have had major foot reconstruction 12weeks ago and still on no load bearing on left foot regime : plates, screws, wire, and am getting bored, have got to get my brain into gear to do some more mods.
Lez
grumpywurzel
Re: have replaced halogen to hid spot bulbs.
Post by grumpywurzel » Wed Jan 25, 2017 3:55 pm
On the E53 get the 55w HID kit from HIDS direct, no error messages that way. Just need to drill a hole on the back of the headlight for the cables, comes with the grommet to deal up the unit afterwards. Job done
2005 X5 3.0d Sport
Post by Horizon » Wed Jan 25, 2017 5:34 pm
[quote="lezmtaylor"]
Most HID kits are error free, as mentioned, when fitting LEDs you need to fit a load resistor equal to the original bulb, so if you had 35w halogens you need a 35 w resistor per bulb.
If you have scanner 1.4.0 or Carly you can disable the bulb out warning for that bulb. I'd try it first to see if it throws an error.
Lez
You think I'd know how to reply properly by now, forgot to scroll down to below the ( quote )
See reply above
Post by X5Sport » Wed Jan 25, 2017 6:23 pm
You might want to run a 50W rated resistor in case a 35W gets hot due to being run 'at the limit'.
lezmtaylor
Post by lezmtaylor » Thu Jan 26, 2017 11:17 am
Silly question..... 50w resistor,  do I solder into pos or neg lead to the bulb ?
Lez
Post by X5Sport » Thu Jan 26, 2017 6:22 pm
Either.  Normally pos but in a DC circuit either is fine as the current still gives through the resistor to get to ground.
lezmtaylor
Post by lezmtaylor » Fri Jan 27, 2017 9:35 am
Thanks for that, now to get the soldering iron out.
Lez
