Thermostat or Not?
MattX
Thermostat or Not?
Post by MattX » Mon Jan 23, 2017 7:17 pm
First winter with my 2012 30d
It seems to take a fair while for the engine temp to rise to halfway since it got cold. It gets there and the air from the blowers is nice and hot even before.
Is this common or is the thermostat on the way out?
graemeX5
Re: Thermostat or Not?
Post by graemeX5 » Tue Jan 24, 2017 8:00 am
It will depend on several factors the air temperature, the driving/ or sitting stationary in traffic and how high you have the heater.
I would say if the heater is warm and heating the car then it is working fine, but you are taking the warm water from the system and running it through the heater to warm the car, so the car warms up slower.
A quick check would be to switch the heater off completely and do the same drive as the previous day and you should see the engine warms up a lot quicker and if it does I would say it is definitely working.
It would just be down to the cold weather, remember that when driving the engine will be getting cold air sucked into the radiator and the engine area which all has a cooling effect.
If the car still doesn't get up to temperature, and the handbook should state the normal operating temperature range, then you could have a problem and a sticking the thermostat is the most likely cause and can be taken out and then needs to be tested.
Hope that helps
Pinewood
Post by Pinewood » Tue Jan 24, 2017 9:09 pm
My engine gets to halfway on the dial within 5 miles from a cold cold start. I think you have a sticking thermostat
Sent from my iPhone
Pinewood
Thermostat or Not?
Post by Pinewood » Wed Jan 25, 2017 10:05 am
Checked it again this morning with a very short 1.5 mile trip to the dr's. the temp gauge was at 10 o'clock by the time i got back home so a 3 mile journey with a 25 min break between both legs. Car had been sitting all night, outside temp 0C
Sent from my iPhone
MattX
Post by MattX » Wed Feb 01, 2017 3:38 pm
It's wierd that the heaters work though don't you think Pinewood?
Graeme, I'll try it without the heaters when I'm on my kwn. Usually have the baby in thr car though so heaters n on hot  :))
MattX
Post by MattX » Thu Feb 02, 2017 9:15 am
Drove this morning with no hot air and it went to 12 o'clock much quicker.
