Anybody changed the steering wheel angle sensor on a 4.6?
E53X5SPORT
Post by E53X5SPORT » Mon Jan 02, 2017 6:57 pm
I have a few lights on my 4.6, codes point to steering wheel angle sensor, has anybody had this done? If so how much did it cost?
IanP
Re: Anybody changed the steering wheel angle sensor on a 4.6?
Post by IanP » Mon Jan 02, 2017 7:34 pm
Yes its not difficult as you split the steering column to get it off. Make sure you get the steering wheel at the correct angle when you put it back  >:( >:( Took me about an hour as you have to work upside down, if you do it yourself it will need coding into the car when you are done. Sensor was under £100 but that was about 5 years ago
Post by henrym3 » Mon Jan 02, 2017 8:47 pm
Might I ask what codes you have that point you in that direction. Only ask so as to try and increase the knowledge base.
VW R32 Gone
gchristofi
Post by gchristofi » Mon Jan 02, 2017 10:55 pm
Just adding this in case it's relevant... have no experience with the angle sensor on my x5  but i do remember having a code along the lines of "steering angle sensor implausible" on my e46 after some alignment work was done.  I was able to re-calibrate the sensor with BMW scanner 1.4.0 and that solved the issue.
E53X5SPORT
Post by E53X5SPORT » Tue Jan 03, 2017 10:39 pm
Update: had the codes deleted and all lights have gone off. Happy days.
