X3 boot size not good for golfers
Posted: Thu Dec 29, 2016 7:18 pm
I spend an interesting time at my local BMW dealer today with a tape measure.
I had short listed the X3 but I thought I'd better check that it could accommodate golf clubs. Conclusion is its not a good golf car. Its too narrow to accommodate golf clubs without at least removing the driver and I can't be fagged with that sort of inconvenience. You need 51" into the rear recesses to lay the clubs widthways which is the golfers preference. Also the boot looks tiny. I know its meant to be 550 litres but there must be some creative measuring going on to get that! I had to check that I was looking at the right car thinking it must be X1 but no it was indeed a X3. So I thought I'd check a E70 X5 and again thats too small Yes a X5 is too small to take golf clubs unless you remove the trim on the LHS exposing the Amp and safety triangle which is OK but a bit disappointing. What is the matter with BMW designers it would be so easy to design this properly? As Bowie said "Good God I could do better than that."
Anyway I looked at the boot of an X1 and was surprised to see that it is bigger than an X5 and way bigger than a X3 and would accommodate golf clubs and dogs easily - the world's gone mad.
Why do they feel the need to stuff the useful spaces behind the rear wheels with amps an fuses and ECUs and other stuff that could easily go into the huge space under the floor that should house the spare wheel anyway (another gripe)
Out of interest I went to see a Hyundai Santa Fe just down the road and it has a much better designed boot - a good 3" wider than the X5 and it still manages to design in a tool kit and spare wheel and get better actual MPG. These volumetric measurements tell you nothing about the practicality of boot sizes.
This has not helped me decide which is going to be the car purchase as I'd quite like another BMW in my life but the space design is not good.
