tyre pressures
the shreksta
tyre pressures
Post by the shreksta » Thu Dec 15, 2016 5:35 pm
i have a 2004 x5 3.0d sport with the staggered 19" standard wheels with nearly new michelin diamaris tyres, to me they always look like they need air in them,they always look kinda flatish.
what should the correct tyre pressure be for the car?
Re: tyre pressures
Post by Horizon » Thu Dec 15, 2016 6:35 pm
[quote="the shreksta"]
[/quote] there is a sticker on the the drivers door jarm, it gives pressures for loaded/ unloaded staggered set up SE setup, usually in Bar
the shreksta
Re: tyre pressures
Post by the shreksta » Thu Dec 15, 2016 6:41 pm
ok thanks i will get them checked out
Re: tyre pressures
Post by Alan Gunn » Fri Dec 16, 2016 5:44 pm
The sticker on the the drivers door jarm of my car doesn't list 19".
I have only just got the x5 with 19"and would like to know what others put in as i have put mine at 32psi all round.
Re: tyre pressures
Post by X5Sport » Fri Dec 16, 2016 6:06 pm
That's interesting considering wheels offered were from 17" to 21".  2.2bar (~32psi) was the 'norm' from memory unless heavily loaded.  It's what I ran my 19" staggered set at.
Re: tyre pressures
Post by Alan Gunn » Fri Dec 16, 2016 7:11 pm
Mine are the 19" staggered so 32psi is ok then no wear problems then ?.
Re: tyre pressures
Post by X5Sport » Fri Dec 16, 2016 8:00 pm
I had even tyre wear all round on mine.  Michelin Diamaris and used two sets in 53,000 miles.
Moments
Re: tyre pressures
Post by Moments » Mon Jan 02, 2017 10:00 am
I found that the last set of Diamaris tyres had uneven wear around the circumference and also more wear in the centre (I've found this with other Michelins on my E46) so I changed these out for Latitude Sport 3.
Pressures 2.2 bar; check at least every two weeks. I got 26k front and 18k rear from the Diamaris set but have since then changed most of the rear suspension, so no wear data of significance. Also, currently running Nokian Weatherproof SUV on my spare 17s - so far these are extremely impressive.
themoog
Re: tyre pressures
Post by themoog » Mon Jan 02, 2017 12:06 pm
Mine has staggered 19's and I always run 36psi no bother.
