4.8iS Analog gauges problem
4.8iS
Post by 4.8iS » Tue Dec 06, 2016 12:07 pm
As per the title - the X5 gauges are playing up. Car would start normally, would drive for 2 mins and all analogue gauges would simultaneously switch off and drop to zero. Everything else works - illumination, temperature leds, obc and check control messages. If the engine is switched off for more than 5mins, upon restart, all gauges would work as normal.
Have replaced the battery, no change. Alternator charges at 13.8 volts with lights on and seat heating on, so all good there. Everything else on the car works perfectly. INPA shows the following error codes: 63 Messwerktreiber and 189 EBV
Anyone can help?
E53 4.8iS
996.1 GT3 CS Manthey K400
928 GTS 5-spd
928 GTR Race Car
944 Turbo Cup Race Car
E39 540i Touring
Steamyrotter
Re: 4.8iS Analog gauges problem
Post by Steamyrotter » Tue Dec 06, 2016 1:24 pm
Sounds like a dodgy capacitor on the circuit board...
You may need to check out a repair company for that..
Post by henrym3 » Tue Dec 06, 2016 8:49 pm
EBV I believe is the electronic brake valve and is a spurious fault that can appear on an E53 and apparently can't be got rid of. Some sites suggest it's a very common fault but apart from you and me no one else on here has reported having the fault. Am still searching/reading about it. Seen some suggestions it can be disabled. If I find/fix anything I'll put it on  here.
VW R32 Gone
4.8iS
Post by 4.8iS » Wed Dec 07, 2016 12:52 pm
[quote="henrym3"]
Seems it is caused by a sensor/harness issue in the rear left wheel well. Will have a look and will report. EBV error codes for some reason are stored in the IKE, but have no connection with the gauges going off. Have found a company, which claims to be able to fix it for £149+VAT. Will do it around 19th Dec because won't need the car then. Definitely will report back once hopefully solved.
E53 4.8iS
928 GTS 5-spd
928 GTR Race Car
E39 540i Touring
