choke control
Shotgun
choke control
Post by Shotgun » Fri Dec 02, 2016 11:08 am
Hi. I have a 05 e53 4.8 x5 fitted with an x pipe and a k&n filter that I think has an over fuelling issue. it occasionally drives as if the 'choke' has not fully gone off. to put it simply. it seems to be slightly bogged down as if its choked up.If I turn of the engine off  when its warmed up  and leave it for 10/15 minuets when I restart it nearly always clears itself and runs ok. I'm not sure what controls the choke/fuelling. is it a sensor of some sort? or am I getting it totally wrong? many thanks for any replies. cheers.
Re: choke control
Post by X5Sport » Fri Dec 02, 2016 2:38 pm
Fuelling is controlled by the ECU and will most likely be air temperature, air pressure, oil temp and throttle demand sensor controlled - and possibly more factors too.  Unless it has been mapped for the changes to the engine then it will use factory settings which will be less than ideal for the altered set-up you have.
Re: choke control
Post by henrym3 » Fri Dec 02, 2016 8:27 pm
I would add to that a sticking thermostat, which is telling the ECU that the engine is still cold.
VW R32 Gone
Shotgun
Re: choke control
Post by Shotgun » Sat Dec 03, 2016 8:26 am
Hi,thanks for the replies. Sounds like it could be one of a lot of things. I'll check the thermostat first.cheers.
