Morning
I need to replace the starter motor on my 4.6is.
I have been told this is an easy DIY, but where is the damn thing and whaat is the easiest way to access it?!
Thanks,
Sam
Where is the starter motor!?
IanP
Re: Where is the starter motor!?
Its on the drivers side under the car. Accesible by taking off the undershield, and a bit awkward to get too. Disconnect the battery first or things could get a bit sparky
samcoombes
Thanks, presume it is just a case of unbolt (battery disconnected!) and pull out?
IanP
Yes, there are only 2 bolts holding it in, and a couple of wires. Its behind the manifold so a little bit awkward
