Hi all
I've neither noticed or been informed by anything either mechanical or digital that a regeneration has occurred. On previous deisels I've had the warning on the dash and reduced power etc associated with a regeneration.
Is this normal can anyone cast some light on this. I intend to ask the MD to have a look on the diagnostics to accertain just when it last happened.
Regards
Steve
DPFS regeneration
- PioneerSSM
DPFS regeneration
BMW X5 The ultimate driving machine.
Except when you need a parking space!
Re: DPFS regeneration
Without diagnostics the only obvious way to know is that the engine bay fans will keep running at high power when you switch off the engine. This is to stop the (plastic) front of the car catching fire.
I have had a few DPF equipped cars, none with warning lights or power changes, but all have this fan trick. The DPF gets seriously hot during a regen!
Never anthropomorphise computers. They hate that.- PioneerSSM
I have had a few DOF equipped cars, none with warning lights or power changes, but all have this fan trick. The DPF gets seriously hot during a regen!
Yes now you come to mention it I've had this with other deisels, but never with the X5.
Might be worth getting a glow plug check done. If they have failed then the regen won't happen according to several reports on the Forum.
I had glow plugs changed last year. But thanks for that.
Did they do the controller as well? A few on here have reported their controllers failing shortly after the plugs were done.
