The clutch on my AC unit has quit.... the pump worked perfectly until recently, then the clutch wont engage.
had it diagnosed & plugged in... everything is pointing to the solenoid on the AC unit.
checked the eleccy connection... all ok..
so....
anyone have access to the information of getting tge exact pump part number for my car... as there are many variants it seems.
mine is a facelift 2004 3.0D sport..
guessing the reg number will help identify the correce part number for a replacement pump ??
cheers
Grant B
AC PUMP....which one ?
graemeX5
Re: AC PUMP....which one ?
I don't know the part number for the AC pump but the link to realoem should help if you put your vin in or car details it will let you find the part no
http://www.realoem.com/bmw/enUS/select
Hth
Hth
Only one listed on Realoem for that year. I used my old VIN as it is the same year.....and I'm geeky enough (or sad enough -Ed) to remember it.
X5-D-Sport
Many thanks gents..
Just found the correct one on e-bay & got a recon Un-wanted unit for £80 - yay...
Thanks for the responses.
Not bad given they are about £1k from Breaking My Wallet.
