Fronty Cupholder Replacement
alex1985blue
Hey Guys,
The previous owner to me had a ipod kit installed (intervee??) and he drilled a hole through the bottom of cupholder so that he could wire it through into the centre console.
I dont see myself getting one of these kits any time in the future, if every so I was wondering if it is possible to replace the two cupholders on their own or are they plastic welded to the rest of the centre console.
Has anyone ever done any sort of work like this to give me a clue how to replace it? Would it have to be removed from below or pulling it out from above.
Thoughts?
Thoughts?
Current Ride: 2005 E53 4.4 6 speed Auto - Toledo Blue with Cream Nappa with all the toys and 22" Ac Schnitzers
- Sanj
Re: Fronty Cupholder Replacement
Hi Alex,
This is a pig of a job.
They are screwed in underneath, so you need to get the centre console out...
Part should be available - use realoem.com to see if it is there.
alex1985blue
[quote=""Sanj""]Hi Alex,
Part should be available - use realoem.com to see if it is there.[/quote]
NO!! Thats not what I wanted to hear.
Is there are guide on how to take the centre console out?
Alex
Alex
- ChewingBacca
So that's what it was for.
Mine has this DIY hole in the bottom. I just cut a piece of thin rubber to a circular shape and dropped it in as a cover.
alex1985blue
[quote=""ChewingBacca""]So that's what it was for.
Mine has this DIY hole in the bottom. I just cut a piece of thin rubber to a circular shape and dropped it in as a cover.[/quote]
Have to say, that pay be a better idea. Just dont like having a car thats been cut up.
- Sanj
Get some carpet (car type or just balck or even carpet tile and cut to shape) - then glue into place or use double-sided carpet tape.
An idea of what has to be done:
viewtopic.php?f=8&t=868&p=9254&hilit=centre+console#p9254
alex1985blue
[quote=""Sanj""]Get some carpet (car type or just balck or even carpet tile and cut to shape) - then glue into place or use double-sided carpet tape.
viewtopic.php?f=8&t=868&p=9254&hilit=centre+console#p9254[/quote]
I think that will leave the finish looking very non OEM.
Im just playing with the idea of making a exact template up that I can wrap and tape into place, or get another set of cupholders.
Ive seen some on ebay that I could get.
Im more worried about the amount of work it would take to get the console out to replace the part.
BL02WAS
could you not get a grommet to fit the hole? bung type ??
- Sanj
[quote=""alex1985blue""]I think that will leave the finish looking very non OEM.[/quote]
That comment got me thinking...
Do you have the plastic tray that sits over the top of the cup holders?
- ChewingBacca
Let me guess Sanj, close the lid and grip the cup in his teeth?
Problem solved.
Problem solved.
- Sanj
http://cgi.ebay.com/ebaymotors/BMW-E53- ... ccessories
THEN grip withh teeth!
alex1985blue
[quote=""Sanj""]
No, no, no - honest, there's a tray that goes over the top!
Yeah Ive got that tray. Unfortuntely still doen't put my mind at rest that theres a bloody great hole in the centre console
- Sanj
Part available - realOEM quotes:
15 CENTER CONSOLE INSERT, CENTRE 51168408026 $92.57
- ChewingBacca
Is the insert standard equipment? I don't have it.
Looks like it's designed to hold a really big spanner.
- Sanj
LOL! I thought it was strange to have a spanner in the middle!
You must be using your teeth an awful lot then!
Go in and ask parts - think I got mine for under £10 - pretty useless though.
