Hi all,
3 weeks ago my 2007 X5 (3.0L Diesel) went into an official dealer (Vines of Guildford) for a software upgrade.
Since the upgrade I seem to be experiencing much higher diesel consumption. It's literally drinking the stuff!
On board computer shows that consumption is down from an average of 25mpg to just 20mpg - and the journeys are the same.
Any ideas if the upgrade could have caused it (does it remap the engine?) or how improve consumption again?
Best
UF
Software upgrade causing high fuel consumption?
- UrbanFlow
Current Rides:
2007 Black X5 E70 3.0D SE - 7 Seater, Dynamic & Media Packs
1975 MGB Roadster with Rover SD1 V8 conversion, Offenhauser Manifold & Holley Carb - Straight lines only.
2005 Honda Hornet with Akrapovich zorst & other odds n sods.
Previous Ride:
2003 Silver 3.0i Sport E53 X5
Previous Ride:
- Steamyrotter
Re: Software upgrade causing high fuel consumption?
Anything can (and usually does) happen with these!!
I would suggest contacting the dealer that did it and explain the situation to see if they have come across that before??
I would also try disconnecting the battery for a few mins, and discharging the car.
Reconnect and try again!!
Sounds simply silly but has been known to sort many a problem out before!!
john_o
Call the dealer and discuss. How many miles have you done? Do you have carly app and dongle?
Fuel consumption is high during regen. I wonder if for some reason your car is regening now but wasnt before?
Sent from my SM-N910F using Tapatalk
Regens should only happen every 300 miles or so.
