I've broken the rear glass twice now......once when someone bricked it and the 2nd when I left the tailgate up at the tip
Anyway, that's the background that may not be related
Not long before the 2nd breakage I suspected the rear wasn't working but being warm it wasn't perhaps obvious. Now it's cold (post 2nd replacement) I definitely know its not working as the air inside is what eventually clears it
Things tried
Engine running button pressed lights up
Thought it might be the 30 amp fuse in the rear side compartment (near fuel filler) but a test has proven there is 12v either side
Swapped the relay nearby and that appears to be working to
Removed the trim inside near the top of the window and I could see the two wires with a plug from the glass going into what I think is called the diversity unit on the drivers side. One the passenger side is another plug which I think is the power to the diversity unit/glass. Testing the passenger (in) side I could see 12v but prodding the wires on the glass (out) side got no voltage at all
The radio reception is fine so maybe the aerial is working
The remote which I think uses the diversity works fine too
Tinterweb suggests that simply swapping the diversity with a 2nd hand unit MAY temporarily un pair my key in some way which is a high price to find out and be knackered
What have I missed or not tested to figure out the fault?
