Clicking/Relay noise in cabin
Posted: Wed Oct 12, 2016 12:23 pm
by Pete
There is an audible noise coming from around the head unit/air con control unit. It is like a constant clicking/relay noise (going really quickly). As daft as it sounds, the best I could describe it as is similar sounding to roadworks in the distance  :-[
If it is possible, I'll put a video up of it.
Re: Clicking/Relay noise in cabin
Posted: Wed Oct 12, 2016 1:03 pm
by Steamyrotter
the Air con control has a small fan in the back which may be on its way out, or a small bit of debris getting drawn into it..
Pull the controls out and see if the noise is within it
Posted: Wed Oct 12, 2016 1:21 pm
by Pete
Thanks.
I forgot to mention, I can hear it as soon as I get in the vehicle so whatever it is, it is working without needing the key in the ignition.
Posted: Wed Oct 12, 2016 8:12 pm
by Horizon
Fuel pump relay, maybe, does the clicking stop when the engine is running ? Does the clicking stop when you turn the ignition off ? Does the clicking start when you activate the fob to open the car? ?????
Posted: Wed Oct 12, 2016 9:09 pm
by Pete
[quote="Horizon"]
I think it activates with the fob. It doesn't stop if I sit in and lock it though.  I can hear it with engine running if I put my ear close.
Posted: Wed Oct 12, 2016 11:15 pm
by Steamyrotter
The climate control sensor fan comes on when the car wakes.
Mine used to make a hell of a racket..
Posted: Thu Oct 13, 2016 7:45 am
by Greydog
Couldn't be the compressor for the suspension topping up could it?
Posted: Thu Oct 13, 2016 9:35 am
by kjb1
fan motor stuck maybe?
Sent from my iPhone using Tapatal
Posted: Thu Oct 13, 2016 5:39 pm
by Smeeagain
Webasto ....... ? Folk often can't tell where the webasto click (near passenger door), and think it is something/somewhere else
But I think outside temp is supposed to be below 7c for that?
Posted: Thu Oct 13, 2016 8:07 pm
by Horizon
Good call, unplug the multiplug out of the Webasco, that should prove it, you haven't said if it's a petrol or diesel car? All diesels have the webasco I think, only a handful of petrols. It's best to put what variant of X5 you have in your signature to help others help you easier
Posted: Thu Oct 13, 2016 10:55 pm
by Pete
It's a 4.8is
It's definitely around the head unit, heater controls.  I'm going to pull the head unit out some time soon and hopefully identify exactly what it is.
