Water loss
teammccrory
Water loss
Post by teammccrory » Mon Oct 03, 2016 1:25 pm
Folks
My 2006 X3 D MSport is losing water.  My mechanic (BMW trained but not an actual BMW garage) says the head gasket on these never gives an bother.  Is he right?  I think I can see steam from the exhaust.  Any thoughts, please?
Stephen  :)
Re: Water loss
Post by X5Sport » Mon Oct 03, 2016 6:19 pm
Very rare, but like anything, possible.  How fast are you losing it?
Worth taking the oil cap off and seeing if there is any 'mayonnaise' on it.  That indicates water in the oil.
You will get steam from the exhaust until the engine/exhaust fully warm up.
Could be a leaking pressure cap on the overflow bottle which will allow steam to escape when at full temp.
Could also be a leaking overflow reservoir.
jagr
Re: Water loss
Post by jagr » Mon Oct 03, 2016 8:02 pm
Check around the thermostats and front water hoses as any little crack under pressure can lose more than you would imagine.
2011 BMW X3 30d M Sport
MarkG_M3CP
Re: Water loss
Post by MarkG_M3CP » Mon Oct 03, 2016 8:43 pm
Sounds like a faulty EGR Valve or cooler - very common on BMW diesels, the coolant leaks into the exhaust manifold. I would have it checked for cracks etc soon - my 335 almost left be stranded when it finally failed.
Have you experienced any misfiring or coughing, the car, not you :) as this is another symptom.
Current: F80 M3 Competition Package and F20 M135i
Gone: F15 X5 M50d / F30 335d xDrive M Sport / E92 LCI 320d M Sport / E46 320d M Sport Touring / E46 318i Touring
