Good video that explains about auto box fluid and changes.
Steamyrotter
Post by Steamyrotter » Sun Oct 02, 2016 9:49 am
Was browsing as you do and found this
It goes through the things you should look at and gives a good explanation wrt when gearboxes "fail" after a fluid change
https://youtu.be/o690DovjDAc
Enjoy??
Re: Good video that explains about auto box fluid and changes.
Post by X5Sport » Sun Oct 02, 2016 11:33 am
Great find and makes it pretty clear as to why grotty fluid replaced by new can cause so much grief.
The other thing I noted is that if the box/fluid is already bad then new fluid is very likely to tip it over the edge into needing a rebuild rather than making it better.
