Front Washer Jets
MattX
Front Washer Jets
Post by MattX » Mon Sep 12, 2016 5:08 pm
Are they all a bit weak or is it just mine?
I have three and none of them squirt water more than 1/3 the way up the windscreen.
Not sure if I need to get the tools out and have a poke so thought I'd ask what yours are all like fellow x drivers.
Kugaman1
Re: Front Washer Jets
Post by Kugaman1 » Mon Sep 12, 2016 9:43 pm
My 2016 models exactly the same.
Works pretty well as it makes the water run up the screen so you get full screen coverage!
lezmtaylor
Post by lezmtaylor » Tue Sep 13, 2016 2:41 am
there are filters on the jet pumps in the washer reservoir, check they are clear.
Lez
MattX
Post by MattX » Sat Oct 01, 2016 12:07 pm
Totally stopped now.
Where is this filter? Is it buried behind the wheel arch liner?
lezmtaylor
Post by lezmtaylor » Sat Oct 01, 2016 1:58 pm
filter is in the washer bottle,it may me attached to the pumps (can't remember).
As an aside, washer bottle filters usually block up if using inferior additive, genuine BMW stuff is obviously ok and I have found the Lidl additive is fine also.
No doubt others will be along with their suggestions.
Lez
lezmtaylor
Post by lezmtaylor » Sat Oct 01, 2016 2:09 pm
Had a thought, my car is a 2002 4.4 E53, and my comments are related to a pre facelift car, later cars may have different locations for the pumps and filters.
Lez
MattX
Post by MattX » Tue Oct 04, 2016 9:34 am
I couldn't even find an exploded diagram on realoem  :blink:
MattX
Post by MattX » Wed Oct 05, 2016 10:24 am
So yesterday I had a day off with no Mrs around so decided to have a crack.
Jacked the car up, popped the wheel off, removed a bunch of 8 & 10mm bolts from the arch liners only to get completely beaten by plastic sodding pop rivets!
WTF am I supposed to do with them, drill them out? On my E46 they had center cores that you could get out and replace them when done. These just seem to be proper pop rivets made from plastic?
MattX
Post by MattX » Wed Oct 05, 2016 4:51 pm
I've found the diagram on RealOEM now.
http://www.realoem.com/bmw/enUS/showpar ... Id=61_2744
Would you say parts 4/6 are the infamous strainers (depending if you have headlight washers or not) ?
Post by X5Sport » Wed Oct 05, 2016 6:37 pm
Looking at that diagram, yes those are the filters.....or strainers in BMW speak.  :)
MattX
Post by MattX » Sun Oct 09, 2016 12:01 pm
Problem solved.
If you get this issue - even low power spraying all you need to is:
Get a football pump adapter
Disconnect the hose directly before the 3 under the bonnet (theres a black plastic C collar around a grey elbow, just pull it and separate)
Open the filler cap for the washers
Pump as much air in as you can (i used a 12v tyre pump)
Voila.
VEG
Post by VEG » Thu Oct 13, 2016 7:42 pm
Any idea how you get to the filters as I have the same problem, i have tried blowing the pipes clear
MattX
Post by MattX » Sat Oct 15, 2016 11:49 am
The only way to get to them is by taking the wheel off and the inner liners out. They're held in by plastic rivets.
How did you blow in there? It took a lot with a 12v pump before mine cleared itself.
I'm assuming you know it's a blockage and not a failed pump?
VEG
Post by VEG » Sun Oct 16, 2016 4:23 pm
Well the washers were working fine then they were only washing part way up the screen. I assume there is something in the washer bottle causing a blockage as I can hear the pump working.
MattX
Post by MattX » Sun Oct 16, 2016 7:54 pm
Seems like it's only a very short term fix. Mines blocked, been unblocked and blocked again this weekend.
Going to have to get some new clips and then crack on removing it all to clean it out.
