Egr cleaned
pcdee
Egr cleaned
Post by pcdee » Sun Aug 28, 2016 2:27 pm
I decided to clean the EGR valve as the coolant wouldn't go over 85.
After I cleaned it and put it back together  I get 'Emissions high' message.
I used carly app to diagnose the fault and it comes up with Exhaust Gas Recirculation.
I've checked the hose on the valve and the electronic plug which was clean.
I can turn the error of and it doesn't come back until I turn the car off and then when I restart it a couple of minutes later the warning on the idrive comes back and the engine management light turns on.
Any ideas chaps?
Sent from my SM-G900F using Tapatalk
X5 E70 3.0D SE
jagr
Re: Egr cleaned
Post by jagr » Sun Aug 28, 2016 7:09 pm
What did you use to clean it?
The only thing that springs to mind is the spindle has a plate the size of a 10p piece that has been known to come unseated/loose.
2011 BMW X3 30d M Sport
Sidneyjames
Re: Egr cleaned
Post by Sidneyjames » Mon Aug 29, 2016 4:12 am
I cleaned mine and had the same issue, ended up changing 'the egr solenoid' as the garage put it!
pcdee
Re: Egr cleaned
Post by pcdee » Mon Aug 29, 2016 1:02 pm
Sorted!!!! One of the pipes had come of from the engine.
Now to see if I can hit the correct  temp for DPF regeneration
X5 E70 3.0D SE
pcdee
Re: Egr cleaned
Post by pcdee » Mon Aug 29, 2016 9:21 pm
Well after all that the coolant I'd still not getting high enough.
I can get it to over 85 driving in town but on the motorway it's between 67 and 75.
X5 E70 3.0D SE
jagr
Re: Egr cleaned
Post by jagr » Mon Aug 29, 2016 9:34 pm
I take it you have changed both thermostats?
pcdee
Re: Egr cleaned
Post by pcdee » Tue Aug 30, 2016 7:42 am
[quote="jagr"]
I wasn't aware there was two[emoji15]
The one replaced this one:
X5 E70 3.0D SE
jagr
Re: Egr cleaned
Post by jagr » Tue Aug 30, 2016 9:05 am
Thats the EGR thermostat, the main thermostat is below that to the left and looks like this:
http://www.realoem.com/bmw/enUS/showpar ... Id=11_3465
This thread gives a little 'how to'
http://xdrivers.co.uk/forum/index.php/t ... 155.0.html
pcdee
Re: Egr cleaned
Post by pcdee » Tue Aug 30, 2016 2:21 pm
Perfect.....thanks....will try that one.
X5 E70 3.0D SE
