CTEK connection
Posted: Sat Aug 20, 2016 6:01 pm
by CondorX5
I am going to need to keep the old 4.8is on a CTEK maintenance charger - where is the best place to attach a permanent CTEK lead?    Jump point and earth under front bonnet?
Re: CTEK connection
Posted: Sat Aug 20, 2016 6:59 pm
by X5-MK
I've attached mine to the battery and chased through to the rear side. Must admit that this is the best thing I've bought, it's a life saverImage
Re: CTEK connection
Posted: Sat Aug 20, 2016 7:17 pm
by henrym3
I stick mine on the CTEK once a month and use the crocodile clips that came with the kit and use the main power lead connection and earth under the bonnet. I  suppose it would be easy enough to hard wire a neat  connection.
Re: CTEK connection
Posted: Sat Aug 20, 2016 10:15 pm
Mine is to the jump points under the bonnet (same on all our cars).  That way I can trail the charger lead out from under the 'hood' and keep the car securely locked  :)
I use this kit....from that river supplier....CTEK eyelet connector.  I also use a couple of 2.5m extensions if the need arises - keeps the charger in the dry.
Re: CTEK connection
Posted: Sun Aug 21, 2016 10:42 am
by CondorX5
CTEKs are brilliant, have saved many a battery from early death on our cars........
Will hook up a connector permanently again - thanks for the ideas
