I am getting intermittent flat battery all the checks done.
looking to replace battery currently 105ah and 950 cca mechanic says undersized and wodo advise bigger. what are the battery dimensions and what's the biggest that will fit?
what new battery
Re: what new battery
The battery is an 019 format from memory but the figures you quote are correct for a standard E70 battery.
You cannot just swap an E70 battery as the car is fitted with an intelligent charging system meaning it has to be 'told' that a new one has been fitted and what type it is. BMW can do it - and charge accordingly - decent BMW indys should be able to do it, or you can diy with something like the Carly App and adapter.
exon16m
it's quite an odd capacity (most are 95ah and 800cca in this size)and ah for this format 019 will a 020 fit? has anyone tried this.
temotes to try halfrauds new black battery life time warranty one
Can't help with the 020 as you will need to check the mounting plate in the car.
Varta are coming up as a good type and seem more reliable than the Bosch S4/5 types. Is the Halfrauds battery AGM? The standard battery type is AGM (Absorbed Glass Mat) and not the older type 'wet' battery.
exon16m
