How do you remove the aluminium plates from running boards?
scz4
Post by scz4 » Sat Jul 02, 2016 10:05 pm
Evening all,
I've tried cleaning my running boards by removing the plastic grommets and machine polishing using abrasive pads and metal polish, but they still don't meet my OCD standards, but much better! :)
My question is, if i order new ones, how do I remove the old ones and fit them? Are they bonded on, just prise them off?
G
scz4
Re: How do you remove the aluminium plates from running boards?
Post by scz4 » Tue Jul 05, 2016 8:39 am
Hi guys,
Just to clarify, it's these aluminium plates I'm trying to seperate from the running boards, but unsure if they're bonded and therefore just need prised off or are clipped on.
Reusch
Contact:
Post by Reusch » Tue Jul 05, 2016 10:32 am
Me personally keep cleaning the originals you'll get there in the end.
JFT96.YNWA
Current
Jaguar XF
Previous
BMW X5 3.0D
Post by Graeme » Tue Jul 05, 2016 5:18 pm
Atmospheric pollutants attack the  the anodised aluminium surface and once you rub it away with an abrasive  you'll expose bare aluminium.  Aluminium is quite reactive so atmospheric oxygen quickly oxidises it - but not in a smooth anodised way - leaving white dusty deposits of aluminium oxide.  One cure. albeit temporary is to use a little vaseline on a cloth and rub it in.  The treatment doesn't last long though and needs to be repeated.  It's an old trick of the trade to make aluminium surfaces look good just prior to sale!
