Hi All
I have read others problems and the given advices and this has improved my learning curve of this vehicle immensely. So I thought I could tackle my problem, this is it as of now.
The front left passenger door central locking began to fail (I didn't know this would become fatal) and finally did with the door in the closed position. I managed to remove the leather door inner skin with no damage and the masticed noise muffling membrane knowing that had never been removed so the door had never been worked on before. I have purchased the correct secondhand approved working lock/actuator. I removed the electrical plug from the one on the door and fitted it to the replacement, it didn't work.
There were no other problems at the start and now, so no other complications! The three other doors work perfectly
My problems are these:
1.How do I open the door with the original actuator still in place?
2.Could this be a key problem, coding?
3.Could it be an electrical fuse, relay and were are they?
4.How to test the replacement part?
Looking forward to many replies to get my head around!
Central locking, keys, electrics
majic55
