Bloody thing
- ianst0028
Bloody thing
So.....
Whilst down in Cornwall last week I noticed that the starter seemed to be getting a little "lazy"
With that and the occasional odd fault triggering on the way back I figured that maybe it was the battery and seeing as it's new I wasn't really that worried
I took the car to work and ran a test on the battery Friday afternoon and sure enough it came up faulty/replace on the tester
Changed the battery while there doing all the recommended tricks of shorting the leads (while disconnected) and leaving for 30 min
Put the new battery on and started her up lovely
When I got home the central locking wouldn't work and then I noticed that neither did the wipers or the interior lights
Marvelous I thought that'll be transport mode
Today I've managed to get to the car with the laptop and through inpa I can see that it is in power safe mode.....
Ive cleared the fault but now it won't start.... The engine spins nicely but won't even try to start
I'm now trying to configure dis on the laptop so I can have a look but has anyone got any ideas?
I love this car even if right now it's looking like a pretty bbq
Thanks in advance
Thanks in advance
X5 e53 3.0 2002 with LPG
Mpower
Bloody thing
What errors were you getting with INPA other than transport mode?
You may need to reinitialise the keys as the immobiliser is not recognising the keys (if you have two do them both).
- ianst0028
Re: Bloody thing
The only one I could see was power saving mode..... It's still there even after clearing the faults and still no wipers etc also no start
*sad panda*
*sad panda*
- ianst0028
Re: Bloody thing
Also..... Having read Le Man's thread I pulled the gm module out to check there weren't any broken wires there
Mpower
Re: Bloody thing
In INPA find "activate" in menu connection in module GM5 and then you can deactivate power saving mode.
- ianst0028
Re: Bloody thing
I'm using an old version of inpa and can't see that option anywhere
Btw thanks for all your help
Mpower
Re: Bloody thing
I don't have my diagnostic laptop infront of me but from memory there should be transport mode,power saving mode in the function tab from there you can deactivate .
- ianst0028
Re: Bloody thing
i had a good look through on inpa yesterday but couldnt find a way to switch the mode off
i've reset my diagnostic computer to factory xp so hopefully when it's all set up i'll be able to get dis working to switch it off then
Mpower
Re: Bloody thing
[quote="ianst0028"]
Do you have the use of DIS or ISTA?
- ianst0028
Mpower
Re: Bloody thing
[quote="ianst0028"]
i will do later today *fingers crossed*
You should be fine with either DIS or ISTA.[emoji106]
Mpower
Re: Bloody thing
[quote="ianst0028"]
Any luck?
Any luck?
- ianst0028
Mpower
Re: Bloody thing
I feel your pain mate probably need the correct drivers installed to get comms with car
- ianst0028
Re: Bloody thing
It's driving me a little mad ..... I've got all the BMW software to do the job but configuring it is troublesome
it'll just be nice to be able to see where i'm going in all this torrential rain we're getting (i'm not actually driving it without wipers)
