3.0 petrol oil leak
strummer
3.0 petrol oil leak
Post by strummer » Mon May 30, 2016 4:27 pm
Hi all
    My X5 has an oil leak,both sides of the engine are dry,I can see oil in the pan under the engine and it is dripping from the plastic cover underneath,any ideas for likely suspects?
  thanks
themoog
Re: 3.0 petrol oil leak
Post by themoog » Tue May 31, 2016 3:28 pm
Oil filter housing gasket probably. Difficult to see. Fairly easy to replace.
strummer
Post by strummer » Wed Jun 01, 2016 8:52 pm
Is this where it attaches to the engine, gasket failure?
strummer
Post by strummer » Wed Jun 01, 2016 9:28 pm
seems a bit of a mission to replace looking at how to's on youtube
Slick
Post by Slick » Sat Jun 04, 2016 10:02 am
Common on the 3.0 petrol engine is a blocked breather pipe, if you have no history of it being recently changed it would be advisable to change the pcv valve ( breather) and all its related hoses too.
my first X5 was a 3.0 and the breather was blocked and the dip stick tube where the oil return connected to it was blocked too, causing the cam cover gasket to leak, worth checking the dipstick tube too
Jaguar F type
X5 4.4 facelift
Vauxhall Vectra diesel  daily driver
strummer
Post by strummer » Sat Jun 04, 2016 11:34 am
Where is the pcv valve,what's it like to replace?
Slick
Post by Slick » Sat Jun 04, 2016 1:16 pm
Its under the front of the inlet manifold and its a tad fiddly to change ,  Oh  and its called a CCV valve on this video.....
https://www.youtube.com/watch?v=E3ve7S8sZcI
Jaguar F type
X5 4.4 facelift
strummer
Post by strummer » Mon Jun 06, 2016 10:15 pm
cheers for the replies I may look at taking it to the local indy to get looked at
strummer
Post by strummer » Sat Jun 25, 2016 8:14 am
Ccv valve was blocked and oil filter housing leaking at join to head sorted by local indy
