Reverse camera
Posted: Sun May 29, 2016 9:32 pm
by Matthew riseborough
Hey
I am new to this forum so am looking for some help.
Today I fitted a reverse camera to the BMW one for which I had to remove the rear number plate lamp which I done and wired the new light and camera all in and all works fine but now I have a message come up saying I have a plate light out is there a way of getting rid of this?
Re: Reverse camera
Posted: Sun May 29, 2016 10:33 pm
by jonsteele
Is the new bulb an LED? If so it won't be pulling enough current for the car to detect, it then throws an error. If it is an LED, you need to get a CANBUS error free version (cheap enough on eBay). If it isn't, I've no idea.
Sent from the dark side by the power of the force!!
Re: Reverse camera
Posted: Mon May 30, 2016 9:49 am
Unfortunately I can't find a canbus one.
This is the reverse camera I installed
http://m.ebay.co.uk/itm/Car-Rear-View-R ... nav=SEARCH
I have read somewhere that the 1.4.0 software can turn off this light is that true?
Re: Reverse camera
Posted: Tue May 31, 2016 10:05 pm
by TheHerd
Yes you can turn off the numberplate bulb check with the BMW Scanner 1.4, I've done mine.
Re: Reverse camera
Posted: Wed Jun 01, 2016 9:57 am
by fenj66
that looks like the same camera i installed.
i fitted mine next to the number plate light so didnt need to recode the car.
Re: Reverse camera
Posted: Wed Jun 01, 2016 7:14 pm
by robsey29
Does this come up on the sat nav screen when you select reverse? also how is it wired in?
Re: Reverse camera
Posted: Wed Jun 01, 2016 9:13 pm
by fenj66
[quote="robsey29"]
It's all been covered before. Use the search facility and look for reverse camera install.
