Led tail lights
Posted: Sat May 21, 2016 10:47 pm
by Hagar66
Ordered myself a pair of rear led tail lights and was wondering to the guys that have them on there car, did you change the indicator bulbs to led or just kept your normal bulbs in and if you did, which ones did you use?
Re: Led tail lights
Posted: Mon May 23, 2016 4:30 pm
by Hagar66
Lol not one answer!?!?!? Oh well  :no: :no:
Re: Led tail lights
Posted: Tue May 24, 2016 11:01 pm
by TheHerd
I've left the supplied indicator globes in.
You can just see the orange through in sunlight but mostly not noticeable because they are tinted/smoked.
I've had thoughts to put in the stock silver ones or go with LEDs but haven't got around to it.
Let me know how you get on.
Re: Led tail lights
Posted: Wed May 25, 2016 7:43 am
by Richard137
[quote="Hagar66"]
I was watching and waiting, as looking at doing the same myself at a later date.
Re: Led tail lights
Posted: Fri Jul 22, 2016 6:35 am
by Chubz92
Just sent this thread, where abouts did you find the LED lights, and what X5 do you have?
Re: Led tail lights
Posted: Fri Jul 22, 2016 3:02 pm
by Hagar66
[quote="Chubz92"]
I have a 2006 3.0D and I bought my lights from here,
http://www.carparts-tuning.co.uk/Lighti ... 0e53%20led
it says for 98-02 models but they do fit the facelift model
Re: Led tail lights
Posted: Fri Jul 22, 2016 3:12 pm
by Hagar66
Re: Led tail lights
Posted: Fri Jul 22, 2016 5:54 pm
by scz4
Very nice! Easy enough to fit?
I'm sure I read another thread where it was easy to fit physically, but the electrics were a little more tricky, not plug and play. Something to do with putting resistors in place.
G
Re: Led tail lights
Posted: Fri Jul 22, 2016 6:14 pm
by Hagar66
[quote="scz4"]
G
They are plug and play but your right, you will need to fit capacitors as the lights are a bit dim with a slight flicker in them. But saying that, the lights are easy to fit and so are the capacitors, you just need some scotch clips and just attach them to the loom, trust me, if i can do it, so could you lol
Re: Led tail lights
Posted: Sat Jul 23, 2016 11:02 am
by deepblonde
I installed mine- Without capacitors (2006 e53) and I had flicker-
So I fixed it by changing some values in the light module in NCS Expert...
Re: Led tail lights
Posted: Thu Jul 28, 2016 6:00 pm
by TheHerd
[quote="Hagar66"]
Good job, glad you got the capacitors all sorted out now too. These smoked LED taillights look great on Sterling Grey and Le Mans Blue X5.
BTW: While installing the subwoofer box I managed to pull one of the cables out of the loom so needed to remove the taillight to fix it. At the same time I installed the OEM stock indicator chrome bulbs, looks a little bit better with no orange showing through.
Re: Led tail lights
Posted: Thu Jul 28, 2016 6:40 pm
by Hagar66
[quote="TheHerd"]
[quote="Hagar66"]
Good job, glad you got the capacitors all sorted out now too. These smoked LED taillights look great on Steel Grey and Le Mans Blue X5.
Yep really pleased with the look of them m8, thanks for recommending them to me, and yep i did the same, put chrome bulbs in rather than orange bulbs
