self level suspension inactive
andy406
Post by andy406 » Wed May 18, 2016 1:11 pm
Hi Guys, i over loaded the car the other day carrying some paving slabs, now i have a self level suspension inactive  warning showing, and it seems the suspension isn’t as high as it should be. Hope you can help thanks in advance Andy
andy406
Re: self level suspension inactive
Post by andy406 » Wed May 18, 2016 1:40 pm
yaaaay  Got it Sorted, it was the 30amp fuse that had gone  :))
Post by X5Sport » Wed May 18, 2016 4:38 pm
There's obviously only so much you can ask of the compressor then......
themoog
Post by themoog » Thu May 19, 2016 5:49 am
Mine did exactly that yesterday after carrying 1/2 a ton of rubble to the tip. I've had to replace the fuse as well. When I loaded up the car I did thought at the time ' I hope this doesn't knacker up the suspension' as the arches were at rock bottom.
gillie
Post by gillie » Thu May 19, 2016 12:41 pm
My self leveling suspension is inactive and come to think of it I transported slabs/bags of stones recently, which fuse number is it and which fuse box so I can check and rule the fuse out or perhaps its a simple as that, that would be a result.
themoog
Post by themoog » Thu May 19, 2016 2:45 pm
It's in the boot on the right hand side looking from rear. The fuse is the end green 30A.
chrisn7
Post by chrisn7 » Mon May 23, 2016 12:39 am
[quote="themoog"]
It depends on the age of the car. On mine, the rear fusebox lists this fuse in this position, and I found a fuse there - except that only the live side connector was present, and the system is working fine, so there must have been a wiring change at some point.
