Both front doors won't open
nelo
Post by nelo » Thu May 05, 2016 9:44 pm
Hi folks new to the x scene 2003 3.0d e53 x5 got a few jobs done but got few more to sort firstly replaced the remote battery and got central locking working fine but now both front doors will lock with the remote but won't unlock can the solenoid in the door locks be replaced or do I need to buy 2 new locks ?
Secondly after running the car turning off it won't re start and have nearly ran battery out trying to start it again
Would anyone have any ideas ?
Thanks in advance lee :(
grumpywurzel
Re: Both front doors won't open
Post by grumpywurzel » Thu May 05, 2016 10:24 pm
Daft question but will they open using the lock/unlock button in the car?
2005 X5 3.0d Sport
nelo
Post by nelo » Thu May 05, 2016 10:34 pm
Hi mate thanks for the reply
Nope won't unlock from centre console button just all lock then both rears unlock ok but the fronts don't
I have disconnected battery till Monday as away but will poss ask a mate to come round with his computer to see if there's any fault codes logged and will post here to see what can be done
Cheers lee
graemeX5
Post by graemeX5 » Fri May 06, 2016 10:18 am
Im not sure but you said you replaced the battery in the key remote have you recoded the key back to the car after ? as I know when my key went flat I had to do that as it would open and start but not lock car.
It may be worth checking that or testing your spare key to see if same prob at that way you can rule that out I think I did a search and found the instructions on here
graemeX5
Post by graemeX5 » Sat May 07, 2016 8:29 am
Had a look at real oem and there is not much apart from the door lock actuator, but if the fronts lock but won't unlock it logically means the actuator is working at least one way. So assuming the fuses are OK as that would be logical as the door locks.
http://www.realoem.com/bmw/enUS/showpar ... Id=51_7752
I'm not sure but you may want to check the wiring to the door by the door shut as the wire there can wear over time as had that on Astra it would lock but not unlock. When my mate stripped it back the plastic cover he found a couple of the wires had nearly broken and only making contact some of the time hence it would sometimes work and then not.
Not sure what else it would be
nelo
Post by nelo » Tue May 10, 2016 4:58 pm
cheers for the reply graeme i have recoded key to car and lock button works but unlock only the backs open
i can hear a noise from the door lock as if its trying to unlock but sound like there just isnt enough energy in the solenoid to unlock the door and the pass door is stuck closed and i cant unlock it even to replace the door lock if i can get a working second hand one if not its going to have to be a new one £££
any more help would be much appreciated
regards
lee :)
nelo
Post by nelo » Tue May 10, 2016 5:06 pm
right folks going to bite the bullet and get a new door lock can anyone advise a reasonable place i can order spares from namely 51218402539 nsf door lock e53 3.0D 2003
thanks in advance
lee :'(
graemeX5
Post by graemeX5 » Tue May 10, 2016 7:05 pm
try Cotswold BMW as they. Give forum members a discount on parts
Hth
nelo
Post by nelo » Tue May 10, 2016 10:40 pm
Hi Graeme
Thanks for that would you if anyone on xdrivers works there
Or anyone work in bmw spares ?
Thanks lee
Greydog
Post by Greydog » Wed May 11, 2016 7:38 am
Hi Nelo
I had an issue with the passenger door on my X5 the buton would rise when unlocking but the door couldn't be opened.
The only way to access the door lock is to take the door card off. You will need to buy some spare retaining clips as a few will be sacrificed getting the card off but it can be done with the door closed I removed the passenger seat to make life easier.
Once the door card is off I could see the actuator was operating but door lock it's self wasn't moving. I sprayed the lock with penetrating oil and managed to get it moving with a long screwdriver, once it moved I could open the door. That made it easier to see what I was doing I carried on working the lock and spraying it with release agent. When it was moving freely I gave it a good coating with Lithium Spray grease and worked it some more. Then put everything back as it was, take care with the plastic membrane it is important if you have damaged it make sure you seal it up.
The problem is a small amount of water dribbles down onto the lock and over time it rusts up, plenty of lubrication should help. Mine has been fine for the last 18months.
graemeX5
Post by graemeX5 » Wed May 11, 2016 7:52 am
Here is a link about contacting cotswoldbmwmin
http://xdrivers.co.uk/forum/index.php/t ... #msg116237
Hth
Steamyrotter
Post by Steamyrotter » Wed May 11, 2016 1:16 pm
Hot start issues pointing towards leaking injectors.
You may need to get them tested and or overhauled
Look for a bosch injector service centre and have a chat to the tech.
Had all mine tested when i couldnt start when hot, and found 2 leaking through, and the other 4 OK.
Had the 2 refurbished and no problems since.
nelo
Post by nelo » Wed May 11, 2016 3:04 pm
hi steanyrotter it may be worth a look
cheers lee
nelo
Post by nelo » Fri May 13, 2016 6:42 pm
well folks
i've ordered new door lock NSF waiting for it to come in but can any advise how i can get the door open both int and ext handles are fine the solenoid is in the locked position with door closed door card is off but cant figure out how i can get door open with door lock unresponsive on unlock
i have also tried the int central lock switch next to hazard switch not working but have stripped and belled the switch out and is working mechanically and electricaly
would anyone have any ideas ?
thanks in advance lee
Steamyrotter
Post by Steamyrotter » Mon May 16, 2016 1:13 pm
The operation of that button can be coded....
(the switch can be set to not operate if you have deadlocked teh car to stop someone smashing a window and then pressing the button to unlock.  or if you leave someone in the car and lock it you wont be popular!!  :-[ )
It feeds to the Body Module then controls the locks
