TYRE PRESSURE?
Posted: Fri Feb 04, 2011 10:49 am
by andym3
Does anyone know what the tyre pressures should be on the 19" X5 alloy wheels?
Re: TYRE PRESSURE?
Posted: Fri Feb 04, 2011 10:52 am
by Chompers
Andy, I don't know off the top of my head but if you open the drivers door, there should be a lable attached to the 'B' pillar with the required pressures stated depending on how the car is loaded i.e. driver on his/her own to fully load
HTH
Re: TYRE PRESSURE?
Posted: Fri Feb 04, 2011 10:54 am
by gmc15
32 psi all round
Re: TYRE PRESSURE?
Posted: Fri Feb 04, 2011 11:57 am
by Sundayjumper
The label says 2.2 bar, which is 31.9 psi
Re: TYRE PRESSURE?
Posted: Fri Feb 04, 2011 12:22 pm
by andym3
Ok brilliant, thanks for the quick responses! My front tyres are looking abit low, so will check the pressures later.
Re: TYRE PRESSURE?
Posted: Fri Feb 04, 2011 6:53 pm
by Mikee
[quote=""Sundayjumper""]The label says 2.2 bar, which is 31.9 psi
Sounds like you're taking the psi!
Re: TYRE PRESSURE?
Posted: Fri Feb 04, 2011 8:41 pm
by Sundayjumper
[quote=""Mikee""][quote=""Sundayjumper""]The label says 2.2 bar, which is 31.9 psi
Interesting to see you're a Titan fan too. As well as the X5 I have a
Titan Silver E36 convertible for the summer and the wife has a
Titan Silver E46 Touring
Re: TYRE PRESSURE?
Posted: Fri Feb 04, 2011 10:19 pm
by Waka
I meant to post when I had 2 new Toyo Proxes put on the front by my local fitter recently.
I thought the steering was very light and when I eventually checked the tyre pressure 2 weeks later (the tyre pressure warning light came on!), they had very nearly 3 bar in them!
I lowered it 2.4 (I know the door plate says 2.2 but i didn't want to drop it too much too quickly and I have 2.4 in the rears).
Anyway, what's the likely problem of having way too much pressure in the tyres?
Re: TYRE PRESSURE?
Posted: Fri Feb 04, 2011 11:19 pm
by Mikee
You'll have extra tyre wear on the centre of the tread pattern. If they've only been on 2 weeks, presuming you haven't driven 1000's of miles I'm sure you won't have caused any major damage.
Re: TYRE PRESSURE?
Posted: Sat Feb 05, 2011 2:19 am
by andym3
[quote=""Waka""]I meant to post when I had 2 new Toyo Proxes put on the front by my local fitter recently.
I thought the steering was very light and when I eventually checked the tyre pressure 2 weeks later (the tyre pressure warning light came on!), they had very nearly 3 bar in them![/quote]
Firstly I would check for anything that could have caused a puncture etc & if no signs of anything then I would take the wheels back to where the tyres were fitted!
If the tyres have lost all the air in 2 weeks, the beading may not have a tight seal and may need a bit of tyre glue!
If this is the case the tyre garage can not charge you for doing this!
TYRE PRESSURE?
Posted: Sat Feb 05, 2011 8:04 am
by ITBarbie
Hi Waka
Twice now I've been in to have something done with the tyres and twice they put 40 psi in. When I queried it last time the guy told me he was surprised that my car only was supposed to have 32 as others mostly 40 as other large 4x4. I will always tell them in future. And it's right you will get excess wear in the middle but 2 weeks should be fine if you just doing normal runs
Re: TYRE PRESSURE?
Posted: Sat Feb 05, 2011 8:15 am
by Mikee
[quote=""Sundayjumper""][quote=""Mikee""][quote=""Sundayjumper""]The label says 2.2 bar, which is 31.9 psi
Nice E36 you got there. Looks great on those wheels. And yeah, I love silver cars too. Started with my first 318is many years ago in Sterling Silver, then went thru a Cordoba Red 318is and an Avus Blue 328i Sport before realising that I missed the Silver. So when it came to getting the M3 a few years back it had to be Silver. Getting the X5 in 2007 was then a no-brainer, just regret not spending a few extra quid and getting a Titan Silver 4.8!
Re: TYRE PRESSURE?
Posted: Sat Feb 05, 2011 10:48 am
by Waka
Thanks for the replies.
Andy the tyre pressure didn't drop of its own accord, I let them down to nearer the recommended pressure. I think we're confusing bar and psi here
Penny, yes it's worrying if tyre fitters don't know what pressure they should be using and/or can't read the plate that's on the drivers door frame of almost any car telling them what to use!
I love these Toyos though, I got them just before the second set of snow, and going from balding (but legal!) Michelin Diamaris to these is like night and day!
Re: TYRE PRESSURE?
Posted: Mon Feb 07, 2011 12:36 am
by andym3
[quote=""Waka""]Andy the tyre pressure didn't drop of its own accord, I let them down to nearer the recommended pressure.[/quote]
Yeah, thanks mate!
