Can I reset the Inspection Light on Dashboard?
chubbs
Post by chubbs » Sat Mar 26, 2016 2:03 pm
I've looked everywhere for an answer to this question - and failed to find one!
Is there any way to reset this light (see pic below), so that all the green rectangles along the top are illuminated and "INSPECTION" is not illuminated?
Edit - I've already successfully reset the 'oil service' and 'brake fluid service' indications, using the odometer button & ignition key method, but this didn't reset the lights you see in the pic above.
Bubbaspaarx
Re: Can I reset the Inspection Light on Dashboard?
Post by Bubbaspaarx » Sun Mar 27, 2016 11:09 pm
Try this
Ignition OFF (POS 0)
Press and Hold the trip odometer button while turning key to position 1 (ACCESSORY)
Keep the button depressed (about 5 secs.) until you see “Oil Service” or “Inspection” with “Reset” or “Re” in the display then let go
chubbs
Post by chubbs » Mon Mar 28, 2016 9:11 am
That's the method I referred to in my Edit - it's successfully reset the litres/days on the computer, but it hasn't reset the INSPECTTION light and the green bars (as in the picture above).
Thanks for the reply, but does anyone have a solution to this?
grumpywurzel
Post by grumpywurzel » Mon Mar 28, 2016 9:38 am
I know I can can do it with the BMW scanner, not sure if uyou can do it without a reader
2005 X5 3.0d Sport
chubbs
Post by chubbs » Mon Mar 28, 2016 10:40 am
[quote="grumpywurzel"]
Aaaah - thank you so much. I'm glad you said that, because I bought a scanner for 15 quid off Ebay on Saturday. It's coming from China, so hopefully I'll still be alive when it gets here.
Can you give me a rough idea of how hard/esy it is to do? I've never used a scanner before (but I have access to an old laptop with Windows XP, just in case it's needed).
grumpywurzel
Post by grumpywurzel » Mon Mar 28, 2016 11:22 am
[quote="chubbs"]
I found it a bit of a faff tbh, I have only used it twice! And since I plugged it in my front parking sensors have stopped working (threw up a fault with the front off side sensor, so had to switch the fronts off) and the exterior button on the boot  now doesn't work..... coincidence?
It will be buried in one of the modules regarding resetting the service lights, can't remember off hand which one it was?
Which scanner did u buy?
2005 X5 3.0d Sport
chubbs
Post by chubbs » Mon Mar 28, 2016 6:37 pm
I got this one - http://www.ebay.co.uk/itm/291690740134? ... EBIDX%3AIT
Cheap & cheerful, just hope it works.
grumpywurzel
Post by grumpywurzel » Tue Mar 29, 2016 11:40 am
Looks like the same unit that I have, should have BMW Scanner 1.4.0. Once you have used it a few times its fine, getting the program setup on your PC can be a little hit and miss (my anti virus had a hissy fit)
2005 X5 3.0d Sport
chubbs
Post by chubbs » Tue Mar 29, 2016 5:40 pm
Thanks for your help. I'll post up when I've had a go with it.
